Lexus RX 2005
Jack De
On 11/16/2024 at 8:22 AM, Jack De said:
Car starts, but cannot shift out of park but the
still rolls forward. I have emergency brake on
so apparently it act as if it is in neutral.
Help!
Quote
2005 Lexus RX350: Car starts, but cannot shift out of park but the still rolls forward. I have emergency brake on so apparently it acts as if it is in neutral. What could be wrong?
CoPilot answer:
It sounds like your 2005 Lexus RX350 might have an issue with the brake light switch. The brake light switch is responsible for releasing the shifter from the park position when you press the brake pedal. If it's faulty, the shifter won't move out of park even if the brake is engaged.
Here are a few steps you can try:
  1. Check the Brake Lights: When you press the brake pedal, have someone check if the brake lights are working. If they aren't, it's likely the brake light switch is the culprit.
  2. Inspect the Brake Light Switch: The brake light switch is usually located above the brake pedal. You can visually inspect it for any obvious damage or loose connections.
  3. Replace the Brake Light Switch: If the switch is faulty, you'll need to replace it. This is a relatively straightforward repair but might require some basic tools.
