I got 93 sc300 changed fuel pump an cleaned. Old  gas  out gave. It. Tune. Up plugs. An. Wires. An still won't. Start.   Gas.  Not. Reaching. Engine .   Any suggestions
How dirty was the tank? Is there sediment in the lines?
Tank had ol. Black gas was sitting a while. Drained lines. At bottom of tank put all back together clean. With. New. Filter.  Gonna.  Try ecm next take it off??
Can you hear the pump running? Are all the fuses good? The ecm is probably a good bet or a broken wire somewhere
Pump food.  Fuse.  Will check. Again. But.  Think. It's.  Good. Ecm. My. Last. Resort?   I.  Think??
The reason i asked if you could hear the pump is because when i power up my car i can hear the pump. So can you hear it pressurizing? Also dont forget the relays if it has one
