Does anyone know of a simple directions for managing pre-sets?  Adding is easy - how the heck do you remove one?
Checked the owner manual - no mention of removing a preset.
This is the dumbest way to operate a radio when driving - you need to pull over in a gas station to search and change channels
Specifics  add station - OK   Remove station?/     Change sequence # of station - like move a preferred station up to position #1?  Orgainze to have FM stations separate from AM  - or Serius stations?
Frustrating
Quote
Managing presets on your 2020 Lexus NX300 can be a bit tricky, but I’m here to help. To remove a preset station, follow these steps:
  1. Tune to the station you want to remove: Use the radio controls to find the station you’d like to delete from your presets.
  2. Access the preset menu: Press and hold the Lexus Enform Touchpad until you hear a beep. This action will bring up the menu options.
  3. Navigate to preset settings: Select “MENU” and then choose “SETTINGS.” From there, go to “AUDIO” and select “RADIO.”
  4. Adjust the number of preset stations: In the radio settings, you can choose how many preset stations are displayed. Adjust this setting according to your preference.
  5. Remove the preset: Once you’ve accessed the preset stations, find the one you want to remove. Select it, and the station will be deleted from your presets.
As for changing the sequence or organizing FM stations separately from AM or Sirius stations, unfortunately, the Lexus NX300’s radio system doesn’t provide direct options for reordering presets or separating them by type. However, you can manually tune to your preferred stations without using presets if you prefer to keep them separate.
Perhaps this'll work for some of the tasks?
Thanks so much for the help!
