diedroopy Posted April 21 Share Posted April 21 I have a 96’ Ls400 with 269k miles, the car is throwing out code for Transmission shift solenoid E, does anyone have any part numbers, or any tutorials online on how to change it, i know the general process just have no idea what it looks like or where to buy it. any advice would be greatly appreciated! Quote Link to comment Share on other sites More sharing options...
RX400h Posted April 22 Share Posted April 22 I found this information by running a Bing CoPilot search, given your information: Quote Part Numbers: Based on my search, here are some part numbers for the transmission shift solenoid for a 96’ Lexus LS400: Transmission 3Way Solenoid Assembly, No.2: 35230-30010 Lock Up Control Solenoid Assembly: 35280-30040 and 35280-50010 Automatic Transmission 3Way Solenoid Assembly: 35240-300201 Line Pressure Control Solenoid Assembly: 35290-300401 Shift Control Solenoid Assembly: 35270-500101 Other part numbers found: 85420-50020, 7555-02355565, 7555-02399861 You can purchase these parts from various online auto parts stores. Please verify the part numbers with your mechanic or dealership before purchasing. Tutorial: As for the tutorial on how to change the transmission shift solenoid, I found a few videos that might be helpful: HOW TO CLEAN OR REPLACE TRANSMISSION SHIFT SOLENOID TUTORIAL How To Test and Check AUTOMATIC TRANSMISSION SHIFT SOLENOID DIY transmission shift solenoid replacement! Please note that while these videos may not be specific to a 96’ Lexus LS400, the general process should be similar. Always consult with a professional if you’re unsure. Remember to disconnect the battery before starting any work on the transmission to avoid any electrical issues. Also, it’s a good idea to have a drain pan handy as transmission fluid may spill when removing the solenoid. Quote Link to comment Share on other sites More sharing options...
