Leaking from the freeze plug cover.  How do I fix? Is it DIY friendly or should I have my Toyota/Lexus dealership fix it? What materials do I need?  What is the torque for the cover bolts?
Thanks
What is the year and model of your vehicle?
Simple jib to fix. Most lexus the freeze plug is held on by two small bolts. Remove them, take the cover off and clean it up. Put is back on with a silicone bead on it. You will need to drain coolant amd put it back in, or replace it if it is due. Only use the proper Toyota long life antifreeze.
