BATTERY LIGHT
HELLO, SO MY ES350 HAS A BATTERY LIGHT ON AND NEW BATTERY HAS BEEN INSTALLED CHEKED ALL CONNECTIONS FOR TIGHTNESS AND CORROSION ALSO PERFORMED CHARGING SYSTEM CHECK WITH PASSED RESULT CHARGING AT 13.9V ALSO FOUND NO DTC'S NO PROBLEMS FOUND IN STARTING OR CHARGING SYSTEMS AND VEHICLE RUNS FINE AND LIGHT HAS BEEN ON FOR A WHILE  HAS ANYONE RAN INTO THIS ANY HELP WOULD BE APPRECIATED THX
Alternator may charge fine when the vehicle is running, but may still have a bad diode. Thebad diode will allow the battery to go flat when parked and can also cause the Battery light to be on. To check the Diode, set your multimeter to AC voltage on the lowest available scale. If you measure ANY AC voltage across the positive and negative terminal, the Diode is done. Most Alternators do not have replaceable Diodes so you will need a whole new Alternator.
I performed the check with my dvom set to ac voltage and checked across my positive & negative battery terminals with engine running there was no voltage the reading is ovolts
