Hi I have a 2004 rx300. The rear interior dome light only works on the door setting. When I want to turn light on without opening door it does not work. Tried replacing bulb, fuse, and even the actual dome had same issue with replacement I got. Need help.
Did you check voltage to the bulb connection?
