Progressive power steering solenoid o rings
TYDOG3333
Hi, i have a 2000 ls 400, the solenoids clip where the wiring harness plugs into it at  has broken completely off the solenoid. Is there any hope in repairing this? Also what size o rings dos the solenoid take? I am trying to avoid having to replace the whole rack!
The o-rings are typically specified by inside diameter and cross-section diameter, most likely in millimeters. You will need calipers or an o-ring size cone. Have you verified that this component is or is not available, separately?
  • 5 months later...
sorry for the late response! The component is not available by itself, i had to order a new rack and pinion from detroit axle due to this part being broken
