GS450hSE Posted November 30, 2023 Share Posted November 30, 2023 On my 2008 GS450h, owned for six years - BOTH High-Beam Headlights just stopped working simultaneously and without any warning. I noticed it when driving and I tried to use them. The bright blue dashboard light indicator for the main beam comes on, and there is no warning message on the dash. But those headlights aren't working (all the others are). Easy, you say - their shared fuse must have blown. Per the manual, both paper and online versions, one 20A fuse in the engine compartment fuse box handles both L & R main beam lights. So, I went to replace it: To my shock, the corresponding fuse (20A) was perfect, and tightly seated. Continuity-checked with a multimeter. In case the wiring didn't correspond to reality, I checked all the fuses around - all were also OK. So I whipped out my OBDII scan tool app on my mobile (BlueDriver gizmo plugged into the vehicle's OBDII port), but no error code of any kind shows up. The only odd thing I can think of is, in the last year, and only a couple of times - the car is driven thrice a day on average - the left dipped beam light did not come on, but came on when I gave the outside of the housing a thump. Please, what do I try next? I've heard there is a relay in the circuit, perhaps shared between the L and the R high-beam lights. Could this be the culprit - and where is it located? Quote Link to comment Share on other sites More sharing options...
Lexus-CT Posted November 30, 2023 Share Posted November 30, 2023 Are the bulbs LED, Xenon or Halogen? No matter if all kind of bulbs have a limited life, it is very strange that both stopped same time. Could be source to the fuse. Have you tried to see if there is 12V on the fuse? First question is my own curiosity to find out how long time the LED bulbs in the CT probably will last as LED is either difficult to replace or very expensive. Quote Link to comment Share on other sites More sharing options...
GS450hSE Posted November 30, 2023 Author Share Posted November 30, 2023 1 hour ago, Lexus-CT said: Are the bulbs LED, Xenon or Halogen? No matter if all kind of bulbs have a limited life, it is very strange that both stopped same time. Could be source to the fuse. Have you tried to see if there is 12V on the fuse? First question is my own curiosity to find out how long time the LED bulbs in the CT probably will last as LED is either difficult to replace or very expensive. Bulbs are halogen. I confirm they failed simultaneously. There is 12v to the fuse. Quote Link to comment Share on other sites More sharing options...
GS450hSE Posted December 5, 2023 Author Share Posted December 5, 2023 SOLVED. It was the bulbs all along! The high-intensity bulbs must NOT have failed simultaneously, but I only noticed the failure when the second one failed too! Quote Link to comment Share on other sites More sharing options...
Lexus-CT Posted December 5, 2023 Share Posted December 5, 2023 Good it was a cheap solution. Quote Link to comment Share on other sites More sharing options...
GS450hSE Posted September 25 Author Share Posted September 25 Yes! 😀 But now, an intermittent issue with a wholly different front light. Please answer in that thread! Quote Link to comment Share on other sites More sharing options...
Lexus-CT Posted September 25 Share Posted September 25 https://www.ebay.co.uk/itm/302647996440?fits=Car+Make%3ALexus|Cars+Type%3A450h|Cars+Year%3A2008|Model%3AGS&_skw=HID+for+lexus+gs450h+2008&itmmeta=01J8MH4G5BFHESSK17NPSY68SV&hash=item467739f018:g:xZoAAOSwfI1aa656&itmprp=enc%3AAQAJAAAA8HoV3kP08IDx%2BKZ9MfhVJKlzo9s2Nq7R4J%2F7vECEcHh7impjNNqIIWcoMnRdP1bsa4qGyXxonAQTvJGFWd7As6yAFDGaxeIse%2BSojBW9DnTXR47fyVwTRScyaL2ttZ8M9yI3Aj5qVdlI1Wsexw00DWiix%2FxX3fU0nvMu0aMWkruIoUdnCq06xeVx25877aQX2odlCuw8V4ag%2Fa8XkTvhnESvC3VUUoRfps%2BIBG6uWQ1x7O8K2p9HXUovIlLNRdYhSzqIZaHUQNgTth721LJR0pswI9Rgz0kf7g1U5P0dR5UOg%2B22R3HqJ%2FoKdbROhEQ7SQ%3D%3D|tkp%3ABFBMooOSkcVk If changing the whole system (not really expensive) problems should be solved. As long as the 12V supply to the ballast is OK! Quote Link to comment Share on other sites More sharing options...
