brakes are sticking, not releasing
lexuslong
From 2carpros.com:
Quote
This could either be the pedal assembly itself or the power brake booster not allowing the brake pedal to return to the rest position. I would disconnect the pedal from the booster rod and make sure the pedal is free and moves easily. If it does, then I would replace the brake booster. If it does not, then the pedal assembly is the issue.
Brake pedal (as i'm just noticing) never goes all the way up, but sometimes it sticks down enough to stop the car from moving. I have pulled pedal up everytime I used it and brake completely releases the brake.
