Bigger Rims On Rx300
TunedRX300
Anyone has changed RX300 rims to 17" or 18", tires to 235/45/17 or 245/40/18? I am thinking of getting lighter and bigger rims but want to make sure they will fit.
I tried to lift the spare tire and wheel, must be 40-45 lbs just by feel. I know spare rim is steel but those 4 alloy rims are not that much better...so much dead weight that RX300 needs to pull.
Immediately upon purchase I upgraded my 01 AWD RX to 17x8 wheels and michelin cross terrain tires. Installed 1.5" wheel spacers all around so the rear suspension no longer interferes with wide® tire and I can, and have, used snowchains safely, on the REAR ONLY!
NO!
There is a CAUTION warning in your owners manual regarding having greater roadbed traction in the front vs the rear. With FWD or front torque biased AWD (like the RX) it can be extremely hazardous to have more grip in the front than in the rear.
That's why NO tire shop will install studs only on the front and now the rear, liability simply too great.
