Moises Vaz Posted June 4, 2023 Share Posted June 4, 2023 Hello everyone, I have a Lexus IS 250 2015. I was recently changing my interior and puddle lights to Led lights from the OEM lights. Once I got to my puddle lights and switched them to the LED lights I realized that they were not working properly. I noticed that if I slightly twisted the cable the light would turn off once it was twisted back the light would not turn on. After a few times of twisting it, the light quit working which caused the rest of the light to not turn on while the car is turned off. Now I am unable to use the interior light while the car is powered off and I am also unable to lock and unlock my car with the key. Any suggestions? I have already checked my fuse and they all are working once I tested them. As well as disconnected my battery for a while and plugged it back in. Thanks in advance Quote Link to comment Share on other sites More sharing options...
RX400h Posted June 4, 2023 Share Posted June 4, 2023 There could be a problem with the wiring connector. Quote Link to comment Share on other sites More sharing options...
Moises Vaz Posted June 4, 2023 Author Share Posted June 4, 2023 33 minutes ago, RX400h said: There could be a problem with the wiring connector. Is there anything that you would recommend? Quote Link to comment Share on other sites More sharing options...
RX400h Posted June 5, 2023 Share Posted June 5, 2023 If you can wiggle the connector that is near the bulb (if there is one), while the light should be on, that may be a good indicator of a connection problem. Quote Link to comment Share on other sites More sharing options...
