Grab these tabs on both sides and just pull up on them...mines came right off, but you might have to use a crowbar or something similar. Once you have them off, just lift the seat up and pull it foward.
Then remove this 12mm bolt and do the same for the other side...once you've removed these bolts just grab the back rest, pull it up a few inches....then pull it out towards you to remove the back rest.
  • 11 months later...
