OCNLVR Posted October 22, 2004 Share Posted October 22, 2004 Did a quick search here but cannot find a way to change my fog lights? I mean, the space is sooo..tiny! I tried to change the fog lights from the engine area. The fog lights are just under the low beam lights assembly but I am having the hardest time to get my hands in there. Any advice will be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
strmrdr23 Posted October 22, 2004 Share Posted October 22, 2004 on the rx300? we removed the front bumper to reach it...it was a pain. Quote Link to comment Share on other sites More sharing options...
rl9905 Posted October 24, 2004 Share Posted October 24, 2004 Did a quick search here but cannot find a way to change my fog lights?I mean, the space is sooo..tiny! I tried to change the fog lights from the engine area. The fog lights are just under the low beam lights assembly but I am having the hardest time to get my hands in there. Any advice will be greatly appreciated. ← It's really easy to do... I replace both sides of my fog lights. To reach the passenger side of the fog lights - First you have to remove the White tube for the Windshield wiper fluid. Just unscrew it and pull it out... This will give you easier access for the fog on the passenger side. To reach the driver side of the fog lights -First You have to remove the car battery. Once you have it removed, this will give you easier access for the fog on the driver side. Good Luck OCNLVR, When you get them installed, come back and let us know how was it. -Robert :D Quote Link to comment Share on other sites More sharing options...
OCNLVR Posted November 17, 2004 Author Share Posted November 17, 2004 Thanks rl9905 Much easier to change the fog lights with your advice. The key is actually to detach the electrical plug first from the light bulb first then remove the light bulb. The way the electrical cable is contructed it is hard to twist all the way around to remove the light bulb. Thanks again. Quote Link to comment Share on other sites More sharing options...
