Wheel Size
I have a buddy that is running 18x9 +45 all around on his 92 sc400. The front is more aggressive than your 18x8 +35 so you should be OK in the front. It is less aggressive in the rear but the rear can take more so you should be OK too. I also know of someone who has run 18x9.5 +45 which is similar to 18x9 +39. This is pretty close (4mm) to your setup too.
The offsets on the wheels in question will actually push them out more towards the fender than OEM. I think AWJ is concerned about fender rub. If that's the case, adding a spacer will only make it worse. ;)
