v8gasdrinker Posted October 12, 2004 Share Posted October 12, 2004 will wheels that fit 97+ sc400 also fit earlier model years? i have a 92 and i saw these rims on ebay that said they fit 97+ sc400 and 01+ is300 specs: 5 x 114.3 bolt pattern front: 18x8 38mm offset rear: 18x9 35mm offset Quote Link to comment Share on other sites More sharing options...
AWJ Posted October 13, 2004 Share Posted October 13, 2004 They will fit. but those offsets are high. SC3/4 runs +50 oem. They might rub somewhere and the handling will be affected. Quote Link to comment Share on other sites More sharing options...
v8gasdrinker Posted October 14, 2004 Author Share Posted October 14, 2004 would 5mm spacers? They will fit. but those offsets are high. SC3/4 runs +50 oem. They might rub somewhere and the handling will be affected. ← Quote Link to comment Share on other sites More sharing options...
Neo Posted October 15, 2004 Share Posted October 15, 2004 I have a buddy that is running 18x9 +45 all around on his 92 sc400. The front is more aggressive than your 18x8 +35 so you should be OK in the front. It is less aggressive in the rear but the rear can take more so you should be OK too. I also know of someone who has run 18x9.5 +45 which is similar to 18x9 +39. This is pretty close (4mm) to your setup too. The offsets on the wheels in question will actually push them out more towards the fender than OEM. I think AWJ is concerned about fender rub. If that's the case, adding a spacer will only make it worse. ;) Quote Link to comment Share on other sites More sharing options...
AWJ Posted October 15, 2004 Share Posted October 15, 2004 yep +45 is fine. spacers on +35 will be bad with this car. Quote Link to comment Share on other sites More sharing options...
