Gs430 Oil Filter?
This is my first time changing oil on a gs430, i went got a oil filter from Toyota Dealership part #90915-yzzd1, when i got home i took out th oil filter on my gs430 which is part #90915-20004 and replaced it with the new filter. I read in this forum that the yzzd1 filter is for the V6, will that cause a problem to my GS430? I'm concern.
  • 3 weeks later...
Just to let you know, I've got a 98GS400 and I do most of the servicing myself, I actually use a FRAM PH8A. If you go look at the base of a 3600,3614,43,8A they are all the same flange and gasket just a bigger element. With the PH8A I can fill it with a full 7 qt's and it's only about 1/8" over full. I've yet to have any trbl with this use but am looking to see if anyone else does this also and if they have had any trbl. I fill the filter 1/2 to 3/4 full before installing the new one to minimize dry startup while the filter is filling for the first time...
