bobalvis Posted September 28, 2004 Posted September 28, 2004 This unit is dash mounted but has recently quit playing, Gives me error 23. ANy idea what this means? I have been through this entire forum and found nothing to compare to. Many thanks
rwallican Posted September 29, 2004 Posted September 29, 2004 I just read a post under the ls400 forum that may solve your problem. seems that you may have to eject the magazine and check to make sure that all the cds are lined up properly. the writer discovered that he had 2 discs in one slot! good luck.
PIONEERSUBY Posted September 30, 2004 Posted September 30, 2004 ERROR 23 MEANS THE CD ISNT GETTING READ PROPERLY. THE EASIEST CURE WOULD BE THAT THE CD WAS INSERTED UPSIDE DOWN. THE CORRECT WAY IS SHINEY SIDE UP LABEL SIDE DOWN. IT IS EASY TO FORGET ANSD INSERT THE CDS LABEL SIDE UP LIKE ALL PRESENT DAY CD PLAYERS DO IT................................................... IF THERE WERE 2 CDS IN 1 SLOT THAT COULS CAUSE IT OR IF THE LASER CHARGE WAS GONE OUT OF THE CD CHANGER AFTER 10 YEARS USE THAT COULD DO IT........................................................ I CAN REFURB THE 95 TO 97 LS400 CD CHANGER MOST OF THE TIOME FOR 125.00 IF THE LASER IS GONE. THEY SELL FOR 250.00 USED. NO OTHER LEXUS GLOVEBOX CHANGER CAN BE SUBSTITUTED FOR THE 95 TO 97 LS400 CD CHANGER 86270-50090. IT HAS PBUS AND ALL OTHER LEXUS GLOVEBOX CHANGERS ARE MBUS . THE "BUS" IS THE LANGUAGE IT USES TO TALK TO THE HEADUNIT.
ggugs1 Posted March 13, 2006 Posted March 13, 2006 ERROR 23 MEANS THE CD ISNT GETTING READ PROPERLY. THE EASIEST CURE WOULD BE THAT THE CD WAS INSERTED UPSIDE DOWN. THE CORRECT WAY IS SHINEY SIDE UP LABEL SIDE DOWN. IT IS EASY TO FORGET ANSD INSERT THE CDS LABEL SIDE UP LIKE ALL PRESENT DAY CD PLAYERS DO IT................................................... IF THERE WERE 2 CDS IN 1 SLOT THAT COULS CAUSE IT OR IF THE LASER CHARGE WAS GONE OUT OF THE CD CHANGER AFTER 10 YEARS USE THAT COULD DO IT........................................................ I CAN REFURB THE 95 TO 97 LS400 CD CHANGER MOST OF THE TIOME FOR 125.00 IF THE LASER IS GONE. THEY SELL FOR 250.00 USED. NO OTHER LEXUS GLOVEBOX CHANGER CAN BE SUBSTITUTED FOR THE 95 TO 97 LS400 CD CHANGER 86270-50090. IT HAS PBUS AND ALL OTHER LEXUS GLOVEBOX CHANGERS ARE MBUS . THE "BUS" IS THE LANGUAGE IT USES TO TALK TO THE HEADUNIT. i have an error 21 can you help me ggugs1@aol.com
