Hey, long time reader, first time poster here.   Thanks for all the helpful advice so far!  Apologies if this is answered somewhere else, there seem to be a lot of similar cases, but I couldn't find exactly my situation.
I've got a '04 RX330 with the brake lights, VSC, tire pressure, etc...  on the dash.  I went ahead and replaced the brake light switch and the lights went away for about a day, and then they came back.  I then replaced it again with a different switch, and again, the lights went away for a day and came back.   (I tried both the bigger blue switch and the smaller white switch)
Both times, I pulled a P0504 code over OBD2 and I cleared it both times.  Both times that code came back.
Other diagnostics:
  • I tested both switches with my multimeter, they both seem fine
  • I measured 12V, (well, 11.7V) across the plug when the key is in the ON position.
  • I've also tested all my fuses in the box underneath the steering wheel.
  • The car operates totally fine, it runs.
  • The brake lights turn on as expected (all bulbs are working).
Does anyone have any ideas of what else it could be, or what I may need to replace?
Thanks in advance!
Hello, James.
This is also recommended:
  • Repairing or replacing wiring harness or connectors that leads to the brake switch or circuit
Sometimes vibration will cause a wire/connector electrical connection to be intermittent.
Okay, that sounds like a good idea.
I assume that there is some ECU that is reading the switch position, and the fault could be inside that component.  Do you happen to know what/where that component is?
I do not at this time, but I'll see if I can find out where it is.
