Rx330 Wheels
Travieso~13
Whats up again, just a quick questions for all you guys and gals if any.
Would the RX330 Wheels(18" 2004) fit a '92 LS400???
I think they would look good. The only difference is that these are 35mm offset, and LS400 are 45mm offset. Would the creat a problem, other than that they are also 5X114.3.
Any help or suggetions would be great!!!
Thanks
I got these 18" to fit my 1996 SC400! They cleared all calipers; except the fronts are little closer to the rim. I put 225/45/18 tires on them to stay closer to the original set up of 225/55/16. The wheel sticks out 10 mm on each side due to the different offset (SC400 has possitive 45 mm offset). All these do is increase your steering track by 20 mm (0.787"); not enough to effect the perform of the car in my opinion. Look pretty sharp...
ANY PICS?
