Driver Door
RFeldes
Good Day,
There is some kind of electronic sensor inside the lockwork that "reads" your key when you insert it and deactivates the alarm. These get worn out with time, so the doors are unlocked with the key, but the alarm is not deactivated, thats why it goes off. You will have to use your lock/unlock button on the key or keep opening the door from the passenger side until you get that sensor worn also, and then you will have to replace the complete lockwork, I guess expensive but really dont know for sure.
