Rx300 Vsc/abs Warning Light
tnongmaton
I accidentally ran over pieces of wood on I40 and a piece of wood got stuck under the chassis near the left rear wheel. I don't know what happened suddenly the VSC/ABS light turned on. I took out the piece of wood and checked if there was any damage on the affected wheel e.g. leaks or breaks, but there was none. Is there a way to reset the VSC/ABS light? Please help. Thanks
ABS wheelspeed sensor or its wiring was damaged......
A slight movement, not something a quick visual would detect, of the sensor away from the gogged surface and it will not be functional.
