GnSc40095 Posted May 19, 2003 Posted May 19, 2003 Calling all help...Having problems with the fog light bulb, finding it difficult in removing the (bulb) wire connection from the main socket. I'm afraid...that if I tug at the wire too hard I'll break off the metal connector from the bulb. Any suggestions would be helpful.
AWJ Posted May 20, 2003 Posted May 20, 2003 If you are talking about getting the bulb out of the socket itself, then you'll have to wiggle the bulb every direction possible while holding the socket in solid position. Those bulbs fit tight. Really tight. Just keep working it is all I can really say. I've broken automotive bulbs in their socket before and it is not really a fun thing to deal with but a little flathead screwdriver does the trick clearing the remenants. Patience and elbowgrease.
