Jake Johansson Posted January 25, 2023 Share Posted January 25, 2023 Hello, my AC works, but only on passenger side. Any clue as to what the problem is and how to take care of this? thanks Quote Link to comment Share on other sites More sharing options...
RX400h Posted January 26, 2023 Share Posted January 26, 2023 From justanswer.com: Quote Your 2007 ES350 has two Air Mix motors that control the AC/heating from side to side . You have one for the LH side and one for the RH side mounted on the sides of the AC/Heater housing and if you have lost temp control on the passenger side then in most cases that usually means the Air mix motor has failed. See its location in the link below. These motors can be accessed from under the dash and through the glove box on the RH side . And here's a post about a similar problem. Quote Link to comment Share on other sites More sharing options...
