Interior
this problem is my passenger seat is broke the left side moves but the right does not. the dealer wants $1300 for a replacement, I can not do that I need help in fixing if possible. It's a 1993 sc300 in tip top w/130000 miles.---- in DISTRESS :angry:
hmm so what your saying is non of the buttons for your power seat are working or are just some of them not working?? it could be a problem with your buttons not making a connection or simply a small wiring problem.
if i were you i would deffinatly pull the assembly out and investigate before you buy a whole new seat it might be easiest to just unbolt the entire seat and go from there you may find your problem along the way.
but it sounds to me like there is a wiring or connection problem. hope you fix it and good luck
