1999 Rx 300 Check Engine Light On
Josh
I have about 70000 miles on my RX 300 and the check engine light came on today. I took it Auto Zone and the code is P1153. Air/fuel ratio sensor circuit response malfunction......what now? Is this a major problem or just something to replace? The oil was just changed and I'm due for more maintenence but if anyone has any info on this...I'd really appreciate it! Thanks!
P1153 should be Heated Oxygen Sensor (HO2S) insufficient switching bank 2 sensor 1, which is located in the front by your exhaust manifold. The best condition in which to remove the sensor is when the engine is moderately warm ( NOT HOT). The exhaust maniford has developed enough heat to expand and make the removal easier. You can do it yourself, take it to dealer will cost you arm and leg.
