Craig S. Michael Posted December 22, 2022 Share Posted December 22, 2022 My traction control light came on when I spun my tire on a wet surface and the check engine light comes on with it. How to permanently clear it? I disconnected the battery to reset the cpu and when I restarted the car it stayed off for a little while but then came back on. Quote Link to comment Share on other sites More sharing options...
RX400h Posted December 23, 2022 Share Posted December 23, 2022 You can take it to most auto parts stores for a free OBD II code check. The person doing this should be able to tell you what any codes mean. They can also erase the code after the failed part (if any) is replaced. Quote Link to comment Share on other sites More sharing options...
