Lexusing Posted July 12, 2004 Share Posted July 12, 2004 Good day all, I have notice that my tilt/telescopic does not complete the travel cycle when the key is inserted or removed from the ignition. I found the technical service for this problem but I am not sure how to removed the following parts: 1. End pad surrounding ignition key cylinder 2.No 1 under cover 3.No 2 safety pad 4.Steering columb cover Thank you for your help. KT Quote Link to comment Share on other sites More sharing options...
silvermate Posted July 12, 2004 Share Posted July 12, 2004 the plastic round piece around the igition comes off by just carefully prying it with a flathead screwdriver or equivelant, then you can get to the ignition... i don't really understand "undercover or safty pad is" but you take the sterring collum cover off by taking out a few phillips screws for the bottom of the sterring housing. Quote Link to comment Share on other sites More sharing options...
Lexusing Posted July 12, 2004 Author Share Posted July 12, 2004 Silvermate, these two pads are the two cover under the steering column. Quote Link to comment Share on other sites More sharing options...
silvermate Posted July 12, 2004 Share Posted July 12, 2004 to remove the ignition you have to pry out the surrounding plastic piece (5 inch piece or so surrounding the ignition), pry from the bottom and pop it off once you have that off, just do as i stated above pry the outter ring off to remove the steering housing just remove the 2 bolts underneath the column, look underneath there and u will see them (they could be hex, instead of phillips i'm not sure) take those out and and the housing will come off. Quote Link to comment Share on other sites More sharing options...
Mr_Ferrari Posted July 12, 2004 Share Posted July 12, 2004 Lexusing, As a precaution, please disconnect the negative battery cable before any work is done. Quote Link to comment Share on other sites More sharing options...
Lexusing Posted July 13, 2004 Author Share Posted July 13, 2004 Mr. Ferrari....thanks for the info... Quote Link to comment Share on other sites More sharing options...
