nusource Posted July 4, 2004 Share Posted July 4, 2004 My remote key control would not work when more than 30 feet away from car even in outdoor parking lot when no obstructions. My dealer changed the battery but didn't see improvement. Is this normal?? Quote Link to comment Share on other sites More sharing options...
nusource Posted July 4, 2004 Author Share Posted July 4, 2004 It for a Rx 330 Quote Link to comment Share on other sites More sharing options...
dgorrie Posted July 4, 2004 Share Posted July 4, 2004 My '99 RX300 gets at least double that probably more. Do you have TWO keys? Does the other have the same limitations? I'd day if they operate significantly different, then one is "failing", and if in warranty, maybe get it changed out. As a test, they could also program the transponder from a NEW key to work wirh your car, see if the range improved. If it did, then just insert that transponder into YOUR key, or have them cut the key to match your car. Just some thoughts ... Quote Link to comment Share on other sites More sharing options...
