Dom0324 Posted December 13, 2022 Posted December 13, 2022 hey i have a question i have a 1999 Lexus Es300 getting code p0500 - Vehicle Speed Sensor "A" also my traction light is on those are the only lights on. I have changed both sensors on the transmission under the air box and i have also change the one that also sits a little on the front side of the transmission casing. However I am still getting the same code. When driving my rpms are at about 3500 at 60-65 mph. Also its shift points are real erratic like it doesn't know what gear it is in. Sometimes it will drive fine hitting all 4 gears usually when the car is still cold or when i step on the throttle slow, most times it won't. my speedometer sometimes drops to zero not often but sometimes. Now when i connected my car to a scan tool the scan tool was not able to read my abs system it was grayed out but read my ecm and my srs modules. Should i think my abs module is the cause or should i next look to replace my abs sensors or where should i start?
RX400h Posted December 13, 2022 Posted December 13, 2022 I would not shoot in the dark to try to fix an issue like that. Do you have a code reader that has all the Toyota/Lexus codes?
Dom0324 Posted January 20, 2023 Author Posted January 20, 2023 On 12/13/2022 at 2:53 PM, RX400h said: I would not shoot in the dark to try to fix an issue like that. Do you have a code reader that has all the Toyota/Lexus codes? No just have a basic code reader i got from like of amazon along time ago
RX400h Posted January 22, 2023 Posted January 22, 2023 Maybe something like this would be better: Amazon.com: OBDMATE 9360 Full System Diagnostic Scan Tool Compatible with Toyota, Automotive OBD2 Fault Code Reader Scanner with Engine ABS SRS TPMS Reset Battery Registration for Toyota Lexus Scion : Automotive
