Is The Rx300 Rough On Brakes?
trout
Our 2000 rx300 has 60k miles. It had 38k when we bought it, so i do not know its history.
its really smooth until you need to hit the breaks...if you hit the breaks hard at higher speeds it is pretty rough and vibrates.
Is this normal for the rx300? Or should a brake job cure this?
you could resurface your rotor a little, that should take the vibration out.
Unless the owner before have done that already, u don't want to do it too many times...
Lexus probably tell u to get new rotors...
If this can only be felt on highspeed braking, then i don't think this is warped rotor.
