dsimons Posted June 26, 2004 Share Posted June 26, 2004 At the risk of sounding stupid and showing that I don't read manuals,, what is the proper way to tow a sc430 Quote Link to comment Share on other sites More sharing options...
flanker271 Posted June 26, 2004 Share Posted June 26, 2004 In LS400's equipped with air suspension you need to turn off this feature first before towing. The switch is located on the left side of the trunk, inside the tool box. I don't know if SC's have the same feature. If you don't turn the air suspension feature off the computer will automatically adjust and lower air suspension as soon as the car is being angled up over 25 degrees. This will cause rear of the car to contact the ground and you don't want that to happen. If your SC is air suspension equipped chances are there is a switch somewhere that you can turn off the feature. Quote Link to comment Share on other sites More sharing options...
90LS400Lexus Posted June 26, 2004 Share Posted June 26, 2004 You may also want to try this forum: http://us.lexusownersclub.com/forums/index.php?showforum=3& Quote Link to comment Share on other sites More sharing options...
SRK Posted June 26, 2004 Share Posted June 26, 2004 At the very least insist on a wheel lift, and at best, use a ramp truck. Quote Link to comment Share on other sites More sharing options...
VMF Posted June 28, 2004 Share Posted June 28, 2004 moving to sc forum Quote Link to comment Share on other sites More sharing options...
itmdtr Posted June 29, 2004 Share Posted June 29, 2004 Not meaning to sound rude but, flat bed it. Quote Link to comment Share on other sites More sharing options...
