Help: Inner Tie Rod Removal Tool
Mr_Ferrari
Could someone tell me the cowfoot tool size to removal the inner tie rod? Does
anyone has the procedure from the service manual? The information below is
from Lexus/Toyota steering housing overhaul tool set. I know one of the tools
is a 34 mm crowfoot wrench.
09612-24014 STEERING HOUSING OVERHAUL TOOL SET
09616-10010- STEERING PINION BEARING ADJUSTING SOCKET
09616-10020- STEERING PINION BEARING ADJUSTING SCREW WRENCH
09617-22030-01- STEERING RACK END WRENCH
09617-22040- STEERING PINION BEARING ADJUSTING SCREW LOCKNUT
WRENCH
09617-24011- STEERING RACK WRENCH
09617-24020- STEERING PINION BEARING SCREW LOCKNUT WRENCH
09617-24030- STEERING RACK END WRENCH (34MM)
09612-10022- HEXAGON WRENCH
09612-10050- STEERING RACK SHAFT BUSHING REPLACER
09612-10061- STEERING PINION BEARING REPLACER
09612-24022- CASE
09613-22011- PULLER
I know I need to buy the service manuals.
i nwent out and bought a big monkey wrench. like a 1 and 1/2 inch one that will fit about right. 1 inch is 25.4mm +1/2 which is 12.7= 38.1 so that fits right? well i used it and get a good wrench. because cheap ones go off on the setting when you give it touque
Thanks jzz30! I thought about the exact same thing, but I did not want to possible
damage the nut. I did find a service metric wrench 15-piece set for $50 at overstock.com. Plus I purchase a thin beak jaw adjustable wrench and plastic jaw
covers at Sears.
On the Website I use for my 300ZX nissan, they have a on-line motor/shop manual. I dont know who or how, but maybe someone can put an on-line LS400 manual on this site. I will try to find out how its done. HOpe the management reads this ( Just what they need ,,,more work!)
Ferd/
