Looking For Pictures Of Stereo Removed
Hi guys
Im in the process of buying a new car
Ive narrowed it down to either a 6th gen Celica or a SC300. Im heavily leaning towards the SC300 since it isnt too much more expensive and its a night and day difference performance wise compared to the Celica
I've built a computer system for my car using a LCD display that provides navigation assistance and MP3 playback. A deciding factor for me getting a car is the availability of a prime location to embed my LCD
The SC300 doesnt seem to have a standard double DIN setup so Im concerned about the potential to put a LCD in.
I would appreciate it if someone could post some pictures of the stock stereo removed or pictures with an aftermarket head unit or even pictures of an installed LCD
Thanks
the sc has a 2.5 din space.
i dont have an lcd screen installed so i dont know how i could be of help. but i do know there are a few flush mount lcd screens on SCs. i to am currently looking into building a carputer. just need to find the right programs.
well if you can help me with the screen i can help you with the programs ;)
ive already built mine and have done research for over a year
thanks for posting the pic
did you fab that piece of plastic yourself?
Sure :)
Im using a VIA Epia M10000 motherboard with embedded CPU
Its a very low power solution so its very appealing for automotive use
Im using a Opus 150w DC-DC PSU. This is a specially designed PSU for automotive application. It will automatically power on your computer when the 12v accessory line gets power and powers down your system at a specified delay after the 12v accesory line loses power
For LCD Im using a Lilliput 7" widescreen VGA touchscreen.
For software there are several frontend programs that let you operate GPS, MP3s and other programs from a touchscreen friendly interface. I use a program called MediaCar. Its skinnable so you can make it look however you want
I got all of my information from the good guys over at mp3car.com
Tons of info there
Also, is there a wiring harness adapter sold anywhere?
Audi Carputer
the Audi carputer is so far the best i have EVER seen installed. im sure there are good ones floating around that i havent found though.
no i did not make my own plastic piece, but for the carputer i will.
xenarc makes a 7" touchscreen that should be able to fit. i know there are a few more brands out there but i will need to do a little more research
is there anyone that sells inserts like the custom one you had made
or if anyone sells just the faceplate part of the nakamichi headunit
i just need a piece of plastic that fits the spot and i can cut it and use fillter to remove gaps
  • Join The Club
    Join the Lexus Owners Club and be part of the Community. It's FREE!
  • Recent Achievements
