blueviol Posted June 13, 2004 Share Posted June 13, 2004 Hi, Whenever I turn on the AC at idle, my 95 SC400's RPM hikes up about 500 more, and when I turn off the AC at idle, the RPM settles back to about 500. It's very little noticeable when turning on at high speed cruizing. Is this a usual symptom related to aging vehicle? How can I fix this? Thanks. Quote Link to comment Share on other sites More sharing options...
AWJ Posted June 13, 2004 Share Posted June 13, 2004 It takes work to drive the ac. The load step is normal. You could pull the belt and check the ac clutch and pully if you think there is a problem. Quote Link to comment Share on other sites More sharing options...
blueviol Posted June 14, 2004 Author Share Posted June 14, 2004 Thanks for your feedback. I will have it checked. Quote Link to comment Share on other sites More sharing options...
