john689089 Posted October 20, 2022 Posted October 20, 2022 2005 GX470 All these lights are on, but check engine light is not on. Thought it might be the gas cap, so I resecured it and went through 7 cold starts with no change. In addition, the following things are not working: 1) seat driving position memory switches; 2) clock doesn't maintain setting; 3) A/C doesn't maintain setting; 4) key fob won't lock or unlock; 5) power door lock switch won't work with key out of ignition; 6) headlights don't stay on in Auto when shut off engine; 7) can't adjust power mirrors (stuck in full down). There may be other items not working that I haven't found yet. I'm going to go through the fuse boxes to see if any are blown. Also wondering if this could be a bad circuit board. Anyone got any suggestions?
john689089 Posted October 21, 2022 Author Posted October 21, 2022 Found it! Fuse #29, ECU-B, 10 amp in the engine fuse box. Replaced with the spare fuse that was in the box and everything back to normal operation.
