Under hood fuse/relay box RX350
Ctaylor
How does one get the large fuse/relay box apart. Got it to the point where front wiring box with its clipped in connection wires - is off, but cannot find clips that will release the black plastic boxes to get to the bolted in 140 fuse etc! (I see that the 140 relay is bad, the 2 sides are not touching at all, one side has slidden down, & top of relay box was very discolored, being how I noticed  it!) Is there a good video? I believe it let's loose from the bottom somewhere & bolts are on sides once you get it apart. Please help!
Edited by Ctaylor
Added to description.
