All Activity
- Past hour
FreakaLeek joined the community
- Today
RX400h started following Reset after replacing battery
Yes, after replacing the battery in your 2016 Lexus RX350, you will need to perform a reset to ensure all systems are functioning optimally. Here are the steps to reset your Lexus after replacing the battery: Turn Off the Ignition and Disconnect the Negative Terminal: Before you start, make sure the ignition is turned off. Then, disconnect the negative terminal of the battery1. Wait for 15 Minutes: Allow the vehicle’s systems to reset by waiting for about 15 minutes. Reconnect the Negative Terminal and Turn On the Ignition: After waiting, reconnect the negative terminal and turn on the ignition1. Reset Specific Functions: Follow the on-screen prompts to reset specific functions. This includes resetting the clock and date settings, power windows and sunroof, and the audio and navigation systems. Test the Functionality of Your Lexus After Resetting: After you’ve completed the reset, test the functionality of your Lexus to ensure everything is working properly. Please note that each window has to be reset individually. To do this, start the vehicle and roll each window down and hold for second. Also, all your radio presets will be lost and you will have to re-enter all. If you experience any issues with the functionality of your Lexus after resetting, troubleshooting options are available for common issues during the resetting process. A comprehensive test drive helps identify and address any remaining issues.
- Yesterday
Joe cooley joined the community
Funcar2004 joined the community
Steve8 started following Reset after replacing battery
Do I need to do a reset after replacing battery in my 2016 RX350 and how do I reset? Thanks.
JLeis joined the community
Mr. Lexo joined the community
hwright90 joined the community
P D Khemani joined the community
- Last week
RX400h started following RX350 shifter , Daytime Running Lamps and Is trac necessary?
Traction control can come in handy under the following conditions: Heavy Rain, Snow, or Icy Conditions: Traction control is essential in situations such as heavy rain, snow, or icy roads, significantly improving safety. It helps prevent your car from losing traction, hydroplaning, or potentially crashing. Navigating Curves in Adverse Weather or Making Sharp Turns on Unstable Surfaces: It proves particularly valuable when navigating curves in adverse weather or making sharp turns on unstable surfaces. Driving on Slippery or Uneven Roads: Traction control should be on for most driving conditions, especially slippery or uneven roads. Sometimes a no-start (no crank) conditions indicates that the starter is failing. If the odometer is broken, how can you know for certain how many miles have been driven?
What year is your RX 350? By the way, I've found that Apple is seldom "state of the art". They still do not have an intelligent stylus. and their photo abilities are almost always a year behind that of Samsung. Perhaps it's good that Toyota/Lexus does not imitate Apple.😏
Dennis Lamkin joined the community
Okay, I am 72 years old, but my mind is sharp...why was the shifter designed to be so confusing? I have had 10 or more Lexus' and this is the first time I have been disappointed with the car. The shifter is not intuitive...as one of my sons said, "Dad, you can tell this car wasn't designed by Apple".
Oliv067e joined the community
I found a nice Is400 in good condition that I want to buy. The problem is that it doesn't have the traction control and heated seats package. I don't really care for the heated seats as the car is relatively low priced, but I am for the traction control. Is it necessary? Also the car doesn't start the first time. Is this something I should worry about. And the odometer has been broken for 3 years, but it's a single owner car and has serviced regularly.
Mike Giambra joined the community
Probably going to take some HEAT for saying this, but it's the truth: I've gone thru two dash cams very quickly and finally gave up the notion that electronics operated above the dashboard will last very long. Computer chips/components generate a lot of heat due to higher clock speeds. Add to that temperatures near 150 F in direct sunlight, and you have a situation where components age quicker than they would sitting on your stereo/TV shelf. A good practice is to keep a bright reflective dash or windshield cover in use after parking outside. And always park facing the car away from the sun. That also reduces the heat build up on your seats and seat-backs which in turn reduces wear on the seat fabric. Just whistling past the junk yard.
One running lamp is brighter than the other. I have replaced both bulbs to unsure they are the same and the problem persists. Any ideas?? 208 Lexus GX470
Speedking007 changed their profile photo
Speedking007 started following IMG_4751.jpeg , IMG_0122.jpeg , IMG_0124.jpeg and 2 others
Speedking007 posted a gallery image in Lexus LS 400 and LS 430 Models
Topics
