How do I remove the seat heater switch to check contacts. Heater works in Low but finally after a period of erratic activation on the high side it finally will not light up or heat high.
Thanks.
Mike
Thanks.
Mike
check this out, but only to the seat heater portion.
http://us.lexusownersclub.com/forums/index.php?showtopic=62405&st=0&p=400522&hl=+radio%20+removal&fromsearch=1entry400522
Thanks.
Mike
yepp, those directions are perfect. Once you've got the panel out from the dash, here's how to remove the switch from the wood panel. I just happen to have one of these on my bookshelf from an older project...
To remove the switch, pry this clip with a flathead screwdriver, and pull the switch away a few millimeters
Then hold the switch in this position, and pry the other side, again lifting it away'
And it's out! :)
I'm sure it's not a cheap replacement part or anything serviceable inside even with contact cleaner.
The carbon or contact on the potentiometer is probably worn down and has dead spots.
(nice mods on your vehicles BTW)
