yidaitianjiaous Posted September 17, 2007 Posted September 17, 2007 I just changed two hood struts with Auto Zone parts, cost $19.99 each. works great. For your info, I need not driil the old strut ends to get out the ball hardware. Instead, i used a tiny screw driver (used for my glasses screws ) and dig pin at the end, then used a plyer to pull it out. Just need patience... INFO ONLY FOR THOSE WHO HAVE THE SAME HOOD STRUTS PROBLEM! I have radio reception problem for AM. I installed a antenna mast bought $18 and it work fine th eearly days. these days, it just noisy, no reception at all. I took the antenna out and foudn nothing then installed back. the motor made noise adn no reception either. Today, i took it out again, trying to solve the problem. I found the palstic teeth stripe was bent and wheni turn the radio on, the antenna extended and kah-kah noise at the end. I have taken out the antenna four times. almost tired of took it out again. but problem still exists. Noisy antenna extention, and ban or no raido reception... any suggetstions?
Beowulf Posted September 17, 2007 Posted September 17, 2007 I just changed two hood struts with Auto Zone parts, cost $19.99 each. works great. Do you have the AZ part numbers? -B-
yidaitianjiaous Posted September 17, 2007 Author Posted September 17, 2007 I just changed two hood struts with Auto Zone parts, cost $19.99 each. works great. Do you have the AZ part numbers? -B- Th Auto Zone struts MIGHTY-LIFT LIFT Part No.: C95029 Just ask them for the part. they will say it doens't work on Lexus if you tell them so.... Just take it and gone and install and laugh for saving money.....
pishta Posted September 20, 2007 Posted September 20, 2007 I just changed two hood struts with Auto Zone parts, cost $19.99 each. works great. Do you have the AZ part numbers? -B- Th Auto Zone struts MIGHTY-LIFT LIFT Part No.: C95029 Just ask them for the part. they will say it doens't work on Lexus if you tell them so.... Just take it and gone and install and laugh for saving money..... Thanks, will look into them.
