92Lex Posted October 24, 2004 Share Posted October 24, 2004 You'll need: Masking tape Paper (1) can of Easy-Off oven cleaner (use the yellow can): I tested this on the gas cap door first just to make sure it wouldn't damage my paint (it's a lot cheaper to get that small door painted versus having a whole panel painted). It didn't damage my finish at all....I didn't have to polish either. Use the masking tape and paper and mask off above and below the pin stripe... working on only 2-3 feet at a time. Quote Link to comment Share on other sites More sharing options...
92Lex Posted October 24, 2004 Author Share Posted October 24, 2004 Spray on the Easy-Off and let it soak in for about 2-3 minutes then take a rag and just wipe it off. You shouldn't even have to rub it off...it should just wipe right off with the foam from the Easy-Off. Then remove the tape and paper and use a wet rag to clean up the area. Water neutralizes the Easy-Off. Make sure you wear gloves. It's EASY. Quote Link to comment Share on other sites More sharing options...
92Lex Posted October 2, 2005 Author Share Posted October 2, 2005 If you have any questions, please don't hesitate to email me. Quote Link to comment Share on other sites More sharing options...
Troysc300 Posted October 20, 2007 Share Posted October 20, 2007 Thank God I found this thread! I'm doing this first thing tomorrow! Quote Link to comment Share on other sites More sharing options...
Zagman91 Posted July 24, 2008 Share Posted July 24, 2008 so you spray the easy off on the paper then rub a rag on the paper and then take the paper off Quote Link to comment Share on other sites More sharing options...
Galvin Posted July 30, 2008 Share Posted July 30, 2008 Thanks so much for this post I am doing it tomorrow. Quote Link to comment Share on other sites More sharing options...
