slim Posted February 1, 2006 Posted February 1, 2006 Hello All, The window won't roll up out in the passenger door. Can anyone tell me where I can go to find out how to remove the door panel? Any help would be greatly appreciated. Thanks!! Slim
justin97 Posted February 1, 2006 Posted February 1, 2006 Hello All, The window won't roll up out in the passenger door. Can anyone tell me where I can go to find out how to remove the door panel? Any help would be greatly appreciated. Thanks!! Slim ) REMOVING THE SCREWS First, I removed the speaker cover to see where the screws for side view mirror was located. It was fairy easy to take out the covers, all i had to do was lift it upward with little force and came right out. I wasn't sure if this screw had to be removed to open the door panel but i did it anyway.. 2) PRYING OUT TRIMS I found it easier to pry out the trims using these spots without breaking anything.. I used a taped flat-head screw driver to pry out the trims so i won't scratch anything. The main screw to open the door panel is located under window switch panel. Once the trim is pryed out, disconnect all the plugs from switch panel. 3) OPENING DOOR PANEL / SNAP PLUGS After removing all the trims(door handle, switch panel), use some force to unplug the snap plugs. There are total 7 snap plugs holding the door panel and the door together. Try working from the sides or the bottom. I found easier to unplug these working from the sides first. . Once all these are out, slightly lift up the door panel and should come right out. all copied from thirdmotion
