MR.GS430 Posted June 14, 2004 Share Posted June 14, 2004 does anybody know how to replace the bulb in the power ect button.at night when i turn headlights on that button doesnt light up please help me. Quote Link to comment Share on other sites More sharing options...
GuyTelefunken Posted June 15, 2004 Share Posted June 15, 2004 Ok, ok....You sound like you're begging! Open the ashtray. Pull the entire assembly towards you and out of the dash. Disconnect the plug on the back by pressing the tiny locking clip on the plug. Lift up on the back part of the wood trim in the area of where the four switches are located. Note: There isn't enough wire to completely remove the panel yet. After you lift the back section up a few inches, disconnect all the plugs from the switches in the wood trim. Remove the entire wood trim panel. Note: You may have to turn on the ignition key and press the brake pedal to move the shift lever for clearance to remove the panel. Remove the PWR/Norm/Snow mode switch from the bottom of the panel with a thin blade screwdriver placed between each side of the switch and the plastic holder it is snapped into. Remove the bulb with a small blade screwdriver by turning it 1/4 turn counterclockwise. Visit your local stealer for the bulb. They are the ONLY place you will get it, trust me. Note: The bulb and socket are integral; i.e. one piece. Assembly is the reverse of removal. Get ready to do it again because it seems that once you replace one, another is sure to follow. Quote Link to comment Share on other sites More sharing options...
