marlen mogilever Posted May 31, 2022 Posted May 31, 2022 Hello to the LEXUS OWNERS FORUM! I am 85 years old and bought my 2010 Lexus RX450H brand new and never had a single problem UNTIL RECENTLY! I HAVE THE FOLLOWING SCANNED CODES: POAA6 - HYBRID BATTERY VOLTAGE SYSTEM ISOLATION FAULT POA7A - GENERATOR INVERTER PERFORMANCE HERE ARE THE SYMPTOMS: 1. DRIVE FOR 30 MINUTES OR SO AND THE "CHECK HYBRID SYSTEM" WARNING COMES ON 2. DRIVE FOR THE NEXT 30 MINUTES - "CHECK BRAKE WARNING LIGHT" COMES ON AND "4 WHEEL DRIVE MALFUNCTION" WARNING COMES ON AND THE CAR HAS NO POWER 3. I STOP - DISCONNECT THE STARTER BATTERY IN THE REAR - TAKE OFF THE CONNECTORS (positive and negative) WAIT 5 MINUTES AND RECONNECT - AND THE CAR STARTS AND DRIVES GREAT WITHOUT ANY WARNING LIGHTS! UNTIL THE CYCLE REPEATS ITSELF. CAN ANYONE PLEASE HELP ME? I AM SURE SOME CLUB MEMBER EXPERIENCED THE SAME PROBLEM AND FOUND A SOLUTION. MY EMAIL IS: bha@rogers.com Thanks in advance! MARLEN MOGILEVER
Mr CB Posted June 9, 2022 Posted June 9, 2022 The POAA6 code is a high voltage drain on the batteries. I would take the car in for a checkup. These cars are highly advance and monitor all kinds of things. The fact that you are getting a code is telling you that something is wrong. If you've been driving it since 2010 and no problems that's pretty good. It probably will not take a technician an hour to trouble shoot the problem and give you a fix. I have a 2013 RX450 and I would be taking mine in to someone qualified as I know I'm not.
