RS-R Basic I Active Coilovers 2014-2020 Lexus IS350 F-Sport AWD
Tkhang
1700$ shipped
Brand new, never used, coilovers for the Lexus IS350 F Sport AWD for years 2014 to 2020. This is only for the AWD model.
To my knowledge, this is the only coilover set for the AWD model that is compatible with the factory AVS system.
Purchased new and box was opened to ensure that all parts were received. Decided to go a different route with my car. MSRP is $2199 direct from RS-R. See specs from manufacture below:
Part#: XBAIT197MA
Compatibility: 2014-2020 Lexus IS350 F-Sport AWD
Chassis code:
Preset Approximate Height From RS-R:
Front -30mm to -35mm (-1.2in to -1.4in)
Rear -35mm to -40mm (-1.4in to -1.6in)
Maximum Adjustment Ranges:
Front 0 to -100mm (0in to -4.0in )
Rear 0 to -100mm (0in to -4.0in)
Recommended Adjustments for Optimal Ride-ability:
Front -10mm to -60mm (-0.4in to -2.4in)
Rear -10mm to -55mm (-0.4in to -2.2in)
Spring Rates:
Front 10.0kg/mm
Rear 8.30kg/mm
Compatible with Factory AVS System. Preset Damper Force Adjustment
https://www.rs-r.com/product/lexus-is350-f-sport-awd-basici-active-coilover/
Edited by Tkhang
Price
