Billrv7 Posted June 12, 2021 Posted June 12, 2021 The right rear tail light in the lift gate and quarter panel do not work. Both bulbs are good. All other parking and marker lights work. Anyone have experience to resolve the issue? Bill
Flukesofhazard Posted August 8, 2021 Posted August 8, 2021 Get a $6 current tester and start checking the wires with power on. If there is a broken wire in the harness somewhere you’ll be able to narrow it down that way. Could also check the fuses, though in a stock configuration there aren’t many reasons why you should have this issue aside from burnt out bulbs. If changes have been made to the electrical system though like the addition of subwoofers for example, then there is the chance that something could be shorting out as a result of the modification to the stock wiring harness.
