flanker271 Posted May 6, 2004 Posted May 6, 2004 Actually, I've had this problem for quite a while now. Neither of the two vents on the rear of the console in my 92LS have air coming out of it, even if I open the vent with the black dial on the right. I tried all different settings from my front climate control (fan always on High) but nothing worked. When I'm saying no air, I mean absolute NO air flow....nothing....dead calm. Just wanted to have some ideas on what could be the cause of this problem. Does the two rear vents have their own blower motor or are they just bypass flow from the front? Could it be a broken valve somewhere inside air pipe thats been blocking the air flow? And could it be a stupid fuse somewhere?
UCF3 Posted May 6, 2004 Posted May 6, 2004 Never actually looked into that, but a good possibility one of the cables are malfunctioning. I'd remove the center console, and troubleshoot. I'd stop by Lexus and ask them for a parts diagram for the center console. It won't give you the locations for the screws, but at least you'll know what parts come out.
