oil pan gasket leak 98 gs300
Hello all. I just got handed down a 98 gs300 with 107k on the odometer. Looks like the lower oil pan is leaking at the gasket.
I was searching through some of the hundreds of pages of threads but haven't found anything yet on someone else having this
issue. My big question is does the Engine have to come out to make this repair?
If it doesn't need to come out what is the procedure? From what i can see some of the bolts are not accessible as there is a subframe member running underneath.
Thanks
