ABS sensors replacement
Hi,I am new here.
Anyone has any experience in buying ABS Sensor from the hexautoparts or other auto car parts and accessories online shop below?
https://www.hexautoparts.com/abs-speed-sensors
Seems it's have a good review /feedback on trustpliot.com .  I am thinking of buying from them to install on my old 2001 Lexus es300 but not sure if they are cheap or good.
thanks in advance.
Adesh,
With good reviews from previous purchasers of the sensors, you should be fine. ABS sensors have no moving parts, and just read a magnetic field as the wheel spins, to trigger the ABS module and other computer functions for traction control, etc. Just compare the part with your original for bracket location and fit, and you should be set to go. I wouldn't be too concerned about using them myself, unless they don't compare well to what you remove from the car.
