D2006 Posted January 14, 2018 Share Posted January 14, 2018 Hello everyone, I need your help in dealing with driver side mirror. Mine is 2006 Es330 and every thing is OK except driver side mirror did not go up/down when I reversed. It goes in/out OK. The passenger side mirror has no problem at all, so I guess it's not the switch. Is that the motor caused problem or something else ? How can i fix it and where i can buy parts ? Thanks a lot for your help D2006 Quote Link to comment Share on other sites More sharing options...
pj8708 Posted January 15, 2018 Share Posted January 15, 2018 Hi Danny, It might be that the mirror switch is toggled in the middle position. This turns off the up/down function for the mirror. Move the switch to either the left or right. This might fix your problem, Paul Quote Link to comment Share on other sites More sharing options...
D2006 Posted January 15, 2018 Author Share Posted January 15, 2018 Hi Paul, Thank you for you advise, I did move switch to left/right and only passenger side mirror moved up/down but driver side did not move. Do you think it is monitor/ anuator failure or some thing else? Danny Quote Link to comment Share on other sites More sharing options...
